programmation variateur hobby king hk-hw30A esc
superspike26
salut a tous.
quelqu'un sait comment programmer avec la radio le variateur:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6458&Product_Name=Hobbyking_SS_Series_25-30A_ESC_(card_programmable)
il m'a ete livre sans la notice lors de ma commande.
Marqué juste en sous:
Hi, I try to program this ESC by classiq way.
First I had to say that à bought 4 of them 3 works perfectly, but for the fourth I had to set the trim at low position but it works. So you had to check if the esc work's before starting to program.
Put the transmiter on, then put full throttle. Connect the battery.
You will heard some bips then a melody with 5 bips. That means you entered setup.
First you will heard bit in MORSE wich are parameters that you can change(.SHORT BIP * _ LONG BIP)
. brake
.. LIPO OR NI
...CUT OFF TYPE
....CUT OFF VOLTAGE
_ START MODE
_ . TIMING
_.. RESET
_ _ QUIT SAVING CHANGES
to modify a parameter put throttle at lower position, then for each parameter you wil have some choises. Next the bips will be medium long and louder.
. brake
- off
- - on
.. LIPO OR NI
- lipo (auto count cels)
- - other (probably nimh)
...CUT OFF TYPE
- slow
- - cut off
....CUT OFF VOLTAGE
- low
- - middle
- - - hight
_ START MODE
- normal
- - soft
- - - very soft
_ . TIMING
- low
- - middle
- - - hight
_.. RESET
no choice automaticly quit
To select what you need, put the throttle from lower to upper. Then you will heard a melody with 4 bips, that means changes are confirmed. Next the folowing parameters are listed, as at start.
To quit, juste after confirming melody put throttle down. that's all.
I did it according to my tests, so it might be possible that I did mistakes.
Bye
